bored&stroked
Urban redneck
- AZ
No, they don't. Pretty sure the seals are plastic, not elastomeric.Do oem mikuni rebuild kits come with throttle shaft seals?
They look pretty clean. Just scrape away the crusty crap with a pic or small flathead screwdriver. Use carb cleaner to spray through all the holes. The use compressed air and go through everything again. Use only mikuni carb kits. They seal the best. If the throttle shafts are stiff, different story. Then maybe pull them.
Thats exactly why I was gonna dip it. But I forgot about the throttle shaft possibly having seals, don't have new ones here, and need to ride tomrrow. So carb cleaner only it is for now. Perhaps I'll dip it next week if it still runs badly.chem dip it. I did what you said multiple times through a season and could never get my ski to run right. Chem dipped the carbs and she has ran perfect since.
