- Aspen, Colorado
If so did you do the hull as well? The turf? Chin pad?
Thank you
Thank you
Thank you
Thank you for the tips. My wife and I have both of our car/truck done. I will be having it professionally applied by the company that did the cars.Make sure you read the instructions and don't skimp on surface prep. You have to remove any and all wax or other coatings from the surface first You should also clay bar everything and buff out any scuffs prior to applying the coating.
