JetManiac Black Friday BOGO sale is on!
This year it has again been especially hard to find deals, as well enough inventory to sell, but JetManiac has been working hard all year to deliver inflation busters.
BOGO BOGO BOGO BOGO BOGO BOGO BOGO BOGO BOGO BOGO BOGO BOGO
BOGO Deals - JetManiac has gone BOGO crazy again!! Our popular BOGO sale is back for our 12th year, WOW!
Buy One, Get One at 50% off!!!
JetManiac's always popular Black Friday BOGO sale is here again this year with lots of new items added.
Also you can mix and match as well. You don't have to get 2 of the same item.
Give us your parts list, we will apply as many BOGO specials as apply, and apply any available sale pricing on some other items as well. Don't miss out on our 12th Annual BOGO sale. Sale pricing good through Cyber Monday night. All orders started by Monday night and paid by Tuesday will qualify. Many items are limited to stock on hand.
**For example, you can buy a hood strap kit and get a tow strap or bolt kit 1/2 off.*
Special Black Friday doorbuster sale deals are listed below the BOGO sale items starting on post # 4, and are in addition to the BOGO sale.
JetManiac Yamaha Pump Rebuild Kits
NSK Yamaha Pump Build/Rebuild kit (2 bearings/2 seals) $51.90 sale 45.95
Buy one pump rebuild kit for $45.95, get second kit BOGO for $22.98
Koyo Jap Oem bearing brand Yamaha pump rebuild kit (2 bearings/2 seals) $89.90 sale 65.95
Buy one pump rebuild kit for $65.95, get second kit BOGO for $32.98
Setback Koyo MAG Pump Build/Rebuild kit (2 Koyo bearings/2 seals) $149. sale 109.95
Buy one pump rebuild kit for $109.95, get second kit BOGO for $54.98
JetManiac Ratcheting Hood Strap Kits
Ratcheting hood strap kit $49.95 sale 43.95
*replaces latch or secondary for extra security with stock hood latch
*includes complete SS mounting hardware(bolts, washers, and nylock nuts) for both ratchet and straps.
*Standard bomber strong thick black straps, or lighter weight strap option in black or blue.
Buy one hood strap kit for $43.95, get second one BOGO for $21.98
JetManiac Tow Strap Kits
Towing Carabiners Kit - 'Surf Tested'
These are super high quality marine grade stainless steel tow clips are manufactured by Suncor Stainless for us, and have been surf tested over many years by hundreds of freeriders.
They are stronger than most carabiners and don't have the sharp ends which will snag on ropes and webbing. They are also all stainless, unlike most carabiners which have steel pins which will rust. They are smaller and lighter than most alternatives and have much higher strength rating.
Buy one tow strap kit for $20.95, get second one BOGO for $10.48
JetManiac Handlepole Limiting Rope kit
Limiting rope kit $46.90 sale 42.95
Limiting rope kit includes:
- Stainless tray loop mount
- Stainless allen hardware with washers and nylock nuts
- Carabiners - 2 high quality stainless marine
- Stainless limiting rope pole mount to bottom of pole steering stop
- Solid black Sta-Set rope kit is std. with elastic keeper and clip to pole base area
- High strength Sta-Set HD marine rope, polyester double braid with high strength, low stretch, and extremely durable, yet it still remains soft over time
- Kit is designed to be strong but also super light, total kit weight is only 5 ounces
Buy one for $42.95, get second one BOGO for $21.48
JM Adjustable Foothold and Ebox rear mount bling washers
Adjustable Foothold and Ebox rear mount bling M8 washers 3.49/ea
(Smaller M6 bling available for SJ ebox brackets to hull also available)
Buy one bling washer for 3.49, get a second one BOGO for $1.75
Temp strips
Temp strips (3pack) $19. sale 15.
-for monitoring cyl head, pipe chamber, and waterbox water temperatures
Buy one pack for 15., get a second pack BOGO for $7.50
Power Valve PV rebuild kits
Power Valve Rebuild Kit
(PV gasket, PV bellow, PV upper spring, and PV lower spring)
2 kits needed per 2 cylinder motor
Buy one kit for 35.90, get a second kit BOGO for $17.95
UFO Hull Mounts
JM UFO Std. 6mm stainless hull mount $25./6 pack JM sale $19.99
(base plate 38mm diameter across)
Perfect for gas tank, battery, waterbox, or pipe strap hook mounting to hull. Also can be used for mounting TL plates
and eboxes. Epoxy directly to hull. Marine grade 316 stainless steel construction.
(With Shorty allen stainless mounting bolt for hook)
Buy one 6pack for 19.99, get a second 6pack BOGO for $9.99
JM UFO Std. 6mm stainless hull single mount $6./ea BOGO 2nd one to 3.
Trim cable to hull tube rubber boot seal
Trim cable to hull tube rubber boot seal $8.50 sale 6.90
Buy one trim tube seal for $6.90, get second one BOGO for 3.45
(std size fits approx 5/8" OD trim tubes)
(larger size fits approx 3/4" OD trim tubes)
Mikuni Needle and Seats
Mikuni genuine OEM Needle and Seat
(Sizes 1.5, 1.8, 2.0, 2.3, 2.5)
Buy one N&S for 22.95, get second one BOGO for $11.48
