99 Blaster. I went to change my transmission oil tonight. I didn't think i had enough transmission oil. So I read the manual and it said that 10w-30 was compatible. So after changing the oil, my clutch is slipping real bad
opworm: I then found some more transmission lube in the garage anyways doh, and put that in. The clutch is much better but it is still slipping. My question is, should I change the clutch out right away, or will the slipping diminish if I change the trans oil a few more times?
What a stupid mistake:bad3:
