Frankenstein motor? positives and neg?
yamanube
This Is The Way
Staff member
Mandalor
T motor with X cylinders is superjet standard...I think you mean X cases with T cylinders?
Sent you a PM Corey.
Pros: Cheap, easy to build, good power
Cons: People are starting to find out about them
62t cylinder yes, however, 760cc's baby, 760cc's.
dont make me start talking jetskis. this is a motocross website.
To be technical about jetskis, usually a 64X cylinder is used.
A 62T is a 701 and will fit the X Cases without modification.
Kennay
Squarenose for the _____
Myrtle Beach, SC
My 760 cylinder is a 62t... says so right in between the cylinders. I think they just called the 62t a 64x if it's a 84mm bore.
