Frankenstein motor? positives and neg?
What's wrong with a frankenstein motor? They have there place. I put a 61Xbottom with a 62T top into a vxr and it rocks! :biggrin:
FS Clean 1994 VXRPro with the legendary Frankenstein motor.
Mouthfulloflake
ISJWTA member #2
NW Arkansas
I have a 64x ( stock 760) cylinder at home, Ill check and get some pics, I have 61x, and 62t 701 cylinders to compare it to.
NO difference I can see between the 62t and 64x cylinders.
#ZERO
Beach Bum
Florida - U.S.A.
Actually the sleeves are the same diameter in the aluminum casting from the 62T 701 and 64X or 62T 760 cylinders but the bottom skirts are a bit thinner on the 62T 701 cylinders.
The 62T 701 cylinder can be safely bored to about 84.5 or 85mm without any problems and the port timing is identical to the 760 cylinder.
Also the OEM 760 sleeves will drop right into the 62T 701 cylinder.
Kennay
Squarenose for the _____
Myrtle Beach, SC
And by the way...... Chris, you freaking rock man. I got the tray today, and needless to say, I took quite a few pics to hopefully help you sell some of them. I couldn't be happier. They seem like they will drop right in with little trimming required. Thanks for the awesome price.... now go get busy making me a fire ext. holder :p
I am about to update my build thread in the ski builds forum... make sure to check it out later on
Mouthfulloflake
ISJWTA member #2
NW Arkansas
I spoke wrong above.
the 64X sleeves have the 2mm higher port timing, the several 62T 701 cylinders that I have seen, DO NOT have the 2mm higher exh port timing than 61x engines.
this is why the 62t SUCKS.
Kennay
Myrtle Beach, SC
Um..... that doesn't make very much sense. If 61x cylinders are good, then based on what you just said 61x=62t, and 64x has higher port timing
Kennay
Myrtle Beach, SC
And I just went out and looked again at my motor.... it has the same stamp as yours on the intake side, and on the bottom at the base on the exhaust side, it is stamped with 62T.
Mouthfulloflake
ISJWTA member #2
NW Arkansas
its sort of a joke.
there are some 62T 701 cylinders out there with the same sleeves as a 61x cylinders, they are generally cheaper than 61x cylinders, because everyone goes around saying " 62t cylinders SUCK!"
I like cheap cylinders.
