✴YAMAHA garage sale, 650/701/760! Mostly OEM stuff.
SUPERJET-113
GASKETS FOR CHAMP BRAP!
View attachment 317850 View attachment 317851 View attachment 317852 View attachment 317853 View attachment 317854 SAM_0337.JPG SAM_0338.JPG Have a bunch of Yamaha twin parts I need to start unloading, tired of parts sitting around. I will just keep adding them on here as I go along, so check back!. Most parts will be OEM, few A/M. All items are OBO too! just dont over low ball me..:)
61X 701 head from a WetJet, perfect shape, surface cleaned and ready to go! - $35 shipped
SOLD - Mikuni SBN 44 from a 650, insides are excellent, all stock jetting for 650, will need a carb kit or at least the main round pumper diaphragm - $65 shipped
SOLD - 61X cases from a 94 FX-1, good working cases, all threads good. Super clean and ready to go. - $65 shipped
SOLD - Mikuni SBN 44 from 61X 701 w/Bpipe. Has a billet A/M flame arrestor adapter on it. Has a broken nipple on the pulse plate side. If real interested, can take pics of inside for you. Reduced since broken nipple - $65 shipped
SOLD - Set of 4 couch motor mounts from a WaveRunner III, little dirty but in good working order. - $40 shipped
Assorted 6M6 and 61X intakes with reeds - $25 shipped OBO
Single flame arrestor for Mikuni 44 from a Wet Jet 61X. Base is cast and top is plastic, comes with screws, nice item. - $25 shipped
SOLD - FX-1 Solas X-prop impeller YC-SC-I 17/23 big hub. Good working. Has some vice grip marks on the nose, Blades are in good shape too. - $65 shipped
SOLD - 2 good working clean "like new Bendix". Both have great spring left and when opened by hand and shaken the inner band spring and weights are all nice and tight! - $30 shipped each
61X cylinder ported by Harry at Group K. I took this up to Harry in Ft. Mohave(60 miles from here) and told him to port it fairly wild for freestyle low end punch. Its a great hitting cylinder for sure. Needs 1 sleeve and a bore to be functional again. Or if you wanted to go to big bore it would be a good time to resleeve. Or you could re sleeve back to new 81mm sleeves. This is ported more wild than Harry normally does. I tried to pull one sleeve out as you can see, but it got stuck, due to damage on sleeve from blowing connecting rod bearing. $150 shipped.
Flywheel covers - $15 shipped or free with other purchase deals!
probably 5 or 6 sets of Bed plates
Tons of pos. and neg. cables from PWC's.
Tons of assorted nuts/bolts, anything OEM hardware. Bolt kits like for cases, cyl head, etc. ALL OEM hardware up the yang.
SOLD - Good working starter - $35 shipped.
650 cylinder and head w/ 1 piston - $50 shipped.
SUPERJET-113
More pic, see 1st post for list and prices.. will be adding more too! If you dont see, ask please!
