- Lake Havasu City, AZ USA
stuff! Just ask!
Any stator covers without oil pump hole? And hardwareView attachment 317850 View attachment 317851 View attachment 317852 View attachment 317853 View attachment 317854 View attachment 308433View attachment 308434 Have a bunch of Yamaha twin parts I need to start unloading, tired of parts sitting around. I will just keep adding them on here as I go along, so check back!. Most parts will be OEM, few A/M. All items are OBO too! just dont over low ball me..
61X 701 head from a WetJet, perfect shape, surface cleaned and ready to go! - $35 shipped
SOLD - Mikuni SBN 44 from a 650, insides are excellent, all stock jetting for 650, will need a carb kit or at least the main round pumper diaphragm - $65 shipped
SOLD - 61X cases from a 94 FX-1, good working cases, all threads good. Super clean and ready to go. - $65 shipped
SOLD - Mikuni SBN 44 from 61X 701 w/Bpipe. Has a billet A/M flame arrestor adapter on it. Has a broken nipple on the pulse plate side. If real interested, can take pics of inside for you. Reduced since broken nipple - $65 shipped
SOLD - Set of 4 couch motor mounts from a WaveRunner III, little dirty but in good working order. - $40 shipped
Assorted 6M6 and 61X intakes with reeds - $25 shipped OBO
Single flame arrestor for Mikuni 44 from a Wet Jet 61X. Base is cast and top is plastic, comes with screws, nice item. - $25 shipped
FX-1 Solas X-prop impeller YC-SC-I 17/23 big hub. Good working. Has some vice grip marks on the nose, Blades are in good shape too. - $65 shipped
SOLD - 2 good working clean "like new Bendix". Both have great spring left and when opened by hand and shaken the inner band spring and weights are all nice and tight! - $30 shipped each
61X cylinder ported by Harry at Group K. I took this up to Harry in Ft. Mohave(60 miles from here) and told him to port it fairly wild for freestyle low end punch. Its a great hitting cylinder for sure. Needs 1 sleeve and a bore to be functional again. Or if you wanted to go to big bore it would be a good time to resleeve. Or you could re sleeve back to new 81mm sleeves. This is ported more wild than Harry normally does. I tried to pull one sleeve out as you can see, but it got stuck, due to damage on sleeve from blowing connecting rod bearing. $150 shipped.
Flywheel covers - $15 shipped or free with other purchase deals!
probably 5 or 6 sets of Bed plates
Tons of pos. and neg. cables from PWC's.
Tons of assorted nuts/bolts, anything OEM hardware. Bolt kits like for cases, cyl head, etc. ALL OEM hardware up the yang.
SOLD - Good working starter - $35 shipped.
650 cylinder and head w/ 1 piston - $50 shipped.
I might actually have that. How long does it need to be? Have Oem one from Blaster 2 pump I put in an am hullGot a pre 08 SJ length shaft?
The one I got is 26.5 from the end of the spline to the end of the bearing surface. Not counting the useless threads. If that works lemme know I’ll do 100$ shippedCan’t remember if it’s 26” or 26.5”
27 1/8” over all length. So I guess it’s no good. There’s a guy on here I got my shaft from. Samsquanch I think. Steve Lundy. Nice guy knows his stuff! Give him a shoutMy shaft measured just a little under 26.5” from end to end. But the 08 + shafts are supposed to measure 28” from the research I’ve done. What’s the overall length of the one you have?
Do you have an oem 61x reduction nozzle or a protec one like it?Still have a lot of stuff left. As you can see this add is from 2016 and last updated in 2017, so shipping prices have gone up, so please just ask about any item. Dont worry Ill hook you up with a deal. These items need to go. I have a lot more too, just ask. Its mostly all OEM parts, aftermarket stuff is gone.
