Super Jet 06 SJ - Electric Box Stuck
Lival
Build build build
Connecticut
I removed both nuts, lock washers, and washers from the E-Box. I can't seem to get this thing off. I certainly don't want to break the case. Am I missing a bolt or something?
Watty
Random Performance
Australia
Remove the 4 bolts holding the 2 stainless mounting brackets so they come out with the e-box. Then use a mallet to tap the brackets back and forth until they release from the corrosion holding them to the e-box. Clean up, re-fit the brackets and remember to grease the studs, and b-box holes when you re-install so it doesn't happen again.
dfw
That happens because its a stainless bolt in an aluminum housing. Make sure to use marine grease or pipe thread sealant.
ItsRixter
SoCal Wav Jumping shiznit
Sunny Diego
I thought I was missing a bolt. My ebox is stuck after removing both nuts. I put a flat bar between the rear wall and the ebox and it will not break free! Damn it
