08 wammer/XSream-SS846
Winter project
08 wammer hull
just got my bun knock off pole, looks pimp :scared:
and my 12vien 148mm mag pump
Hull
2008 wammer hull
8 hand hold wamilton hood
Bun adjustable billet pole
X scream footholds
Drive line
XScream SS846
148mm setback Skat mag pump
46mm xscream carbs with boyseen intake
MSD digital total loss
Power Factor Pipe
how much weight diff is the top deck conversion ??
Are you converting RN or SN Hull.. ??
Where did you get Bun knock off ?? and how much.. ??
im converting a 1997 RN.
this wcf top deck only weights 13lbs, its alot lighter, but after reinforcing it might not be to much lighter .
i got the bun knock of pole form maxxx5555 of the x it was 1300 with pole, bracket, hood hooks, and carbon pad
Nice thread
There is a reason why nobody made a "bottom deck conversion" ? I'm thinking that because I've just split a 2001 RN, bottom weight a lot and smc is a big :):):):).....
SterlingSilva
Colorado Springs
if u dont mind me asking what did the xft bulkhead with the dual scuppers set u back? pretty sweet looking.
also do u know if it would work with a wcf/sn topdeck conversion?
thanks
