I have a Rickter XFR with a 850 DASA, 144 set back Skat mag. I am very happy with the set up. Backflip no problem off boat wakes and Surf. And no trim needed in surf. I have Flatwater backflipped but much more technical to flatwater flip.
Moto360
What pipe?
If pfp I say 11/17
Are you talking 11/17 Hooker?
PFP, XM recommended Skat 14/19 (Enhancer/B-pipe) 16/21 (TL/PFP)
First number = leading edge
Last number = trailing edge
Numbers are in angles, so the bigger the number, the more aggressive it is.
Depends on motor and pipe.
The DASA PV motors seem to like low pitch on the leading edge and lots of compression with a PFP pipe to get through the bottom power into the crazy midrange.
thats not really a DASA charactreristic...moreso of the pipe
key with a PFP is COMPRESSION
if not running big CC with high compression the benefit of a PFP will not shine
it was the booze!I'll be running pump gas compression, PFP, MSD TL..... nice swapping posts Idok lol
I run 185psi and have no complaints about the PFP :biggrin:
