I'm definitely not going to blister the hull for this motor. Not because I don't want to do glass work or don't know how, but because I think blistered hulls look like $hit in my opinion unless you hide it under sponsons, which, as heynagel noted would have to be cut up too. I'd rather the hull remain a multi-purpose, multi-engine vessel. I have this triple, a big pin, a small pin, and a hyperkickass small pin that's currently in it, and this is my only SX hull so I'm not gonna make it a "dedicated" triple hull.
Also, DO NOT mill the exhaust ports on the cylinders!!!!! NOOOOO NO NO
heynagel I hope you haven't pulled the trigger on doing that yet... I do NOT recommend doing that at all... milling back on the port ramps, like I said, will have a TERRIBLE effect on volumetric efficiency. Think about the amount of turbulence it creates when you put a shelf right there for the exhaust gasses to jump over while decreasing the diameter that it can flow through. And more importantly, think about WHERE that turbulence will occur.... IMEDIATELY upon exit of the cylinder. A 2-stroke engine would be crippled by this. It would still run, but it will NOT be just a small loss of power, it would be dramatic. You'd literally be better off leaving the 750 in there.
Here's why....
By introducing turbulence to the exhaust flow immediately, you interrupt the sonic pressure wave that a 2-stroke depends on. That sonic wave is what creates the vacuum pulling the exhaust gasses from the cylinder. If the exhaust gas encounters immediate turbulence, the sonic wave will be disturbed and broken apart as soon as it hits the sharp edge of that "shelf" (for the same reason sharp angles are used in sound-proof surfaces; they break up coherent sonic waves. and vice-versa, why a tuba in a marching band is shaped with the same smooth flowing curves as a 2-stroke pipe, to amplify a coherent sonic wave).
If you disturb that wave immediately after it is created, you essentially render the expansion chamber useless. The whole concept of an expansion chamber is based on that coherent sound wave traveling through it. It is designed to expand and amplify the wave (think tuba) before reducing the volume of the chamber down to normal pipe diameter. This amplifies the wave and then causes it to bottle-neck and resonate backwards towards the cylinder until it impacts a much more dense volume of gas (the fuel-air mixture) coming into the cylinder at the same time the exhaust gasses are leaving. When this backwards-moving wave impacts the dense cloud of fuel, it essentially "pushes" it back into the cylinder to ensure that the maximum volume of fuel remains in the chamber as the piston closes over the exhaust port to begin compression. ALL OF THIS IS LOST IF THE SONIC WAVE IS LOST!!!
That means you might as well just lose the expansion chamber completely and just run normal tubing out of the manifold because it wont even have an effect anymore. And of course by doing that, you have a much quicker and easier solution for how to fit the pipe into the engine compartment anyway!! lol
bottom line is... DO NOT mill your exhaust ports!!!
