Hey guys im new to the forums. I have an 02 RN SJ. My motor set up is as follows below... I was considering switching to a 9/15 hooker prop, my ski makes plenty of power at top end just seems like the prop is spinning up to much and not pulling me out the water as i think it should on my bottom end. Do you think my sj is over propped more for top end? Looking for bottom end torque, not worried about losing some top end. Any advice/suggestions would be helpful. Thanks
24/7 Hood, nosepiece, and footholds
Painted and turfed earlier in the spring
730cc ported 62T - ADA girdled head with 180psi - Dual cooling
44mm SBN dual carbs - Riva flame arrestor adapters - Prok flame arrestors - Outerwears
R&D drypipe with Jetworks water injection (setup via Arts instructions)
R&D flow control valve
Modified RN waterbox
Solas 13/17 prop
Wamiltons stubby pump cone
R&D Pro2 intake grate
Wamiltons Trim system with Blowsion lever and Terrycable cable
R&D flush cut rideplate
AC -4" aluminum pole with spring
Lowered pole bracket
ODI grips
0 degree bars
Scupper
Rad Dudes exhaust tube
500gph Rule bilge pump with Blowsion handlebar mounted switch
Surf Seal
Primer
Hood straps
Solas 13/17 prop
ODI grips
0 degree bars
Scupper
Surf Seal
Primer
Hood straps
