144 solas mag 12 vein
john zigler
Vendor Account
wisconsin
Every pump we sell here, gets turned on a lathe, to reduce "press". Press is a term used to measure the amount of force to install bearings. I have seen pumps out as much as .003 which is HUGE.
I charge 45.00 to turn a pump that some ones sends in. ( We do MANY). I can also build it for you, if you want. I would need your shaft. I have bearing/seal kits, spacers and much more in stock.
Can I have a price for the turn, shaft, seal and bearing install. I have new bearings. Much appreciated.
Nick
john zigler
Vendor Account
wisconsin
Nick
My shop labor rate is 85.00 / hr.
I Charge 85.00 to build a "new" pump, with new bearings, good shaft, etc. This includes time, and grease.
"IF" I need to spend time removing your old parts, ( bearings, races, etc) It is more.
Again, 45.00 to turn it on the lathe. We do many here, that people have bought elsewhere.
Please call 608-743-1305 if you want to send in a pump.
eastcoastjumper
James
Long Island
I put mine in with new seals and oem SJ bearings. Filled with ATF and made sure the rear o ring was sealed.
The order came in time, and the price was discounted.
I would like to buy the impros cone for it.
Has anyone got any feedback on these yet please?
I have run mine for about 8-10 hours and have had zero problems and am extremely happy with this product. i know it is a late response but. Zero issues i would recommend this unit to anyone on a budget build for a mag pump
eastcoastjumper
James
Long Island
I swapped the fluid out with 10-40 oil when I changed my prop and short nose cone the other day. I did change the oil a few times throughout last season.
Both mag pumps I purchased have not had a problem with them.. yet. lol
