Does that Solas come with bearings?
I agree, OEM 155. Contract TC Freeride or Speedysprocket they both have done alot of testing with the OEM 155 for prop pitch.
I'm not aware of the solas 148 coming with bearings, but I assumed it would use the same driveshaft and bearings as a 144 setup uses.
I actually do have and for a short period of time ran an OEM 155 setup. I pulled it to swap out the R&D pump seal and replace it with an SBT seal I picked up from JetManiac. When I pulled the pump I recognized the driveshaft spline was only engaging about half an inch into the midshaft.
I had sent the the OEM driveshaft to Chris to have cut and even thought I told him it was for an OEM 155 setup, I think the driveshaft ended up too short. I haven't contacted him about it yet, but I'll see if he can do anything to help me out.
