SOLD 155 OEM Pump Kit for Superjet/AM Hull
Ducky
Back in the game!
Charlotte, NC
Selling an OEM 155 pump kit for Superjet/AM Hull.
This kit includes:
- Brand New SNL Industries Driveshaft (Superjet Length that will work with many AM hulls)
- Brand New Koyo Bearings
- Pump Stator (seal installed)
- Wear Ring (minor sand scratching, normal)
- Reduction Nozzle (I believe this is the 5 degree up nozzle
- Pump Cone
- Pump Bolts
The only thing you would need for this to be 100% ready to install is timesert/helicoil the wear ring and shorten the stock pump bolts or get the correct pump bolts from SNL Industries @Sasquachcrap or Rad Dudes (maybe others sell them). You will also need a pump seal and need to assemble the pump. It’s easy, but I’d rather the buyer assemble themselves for ease of shipping.
Other things you would probably want to do depending on your application is tap the pump for dual or triple cooling, and tap the reduction nozzle side bosses to install a trim setup.
Looking to get $350 plus shipping.
PM me if interested or text/call me at 607-341-3571
Thanks!
Matt
