1987 X2 carb fuel connections cracked
Zero Client
BeerrroooOOOT!!!
Douglasville, GA
Tonight was starting up my new/used ski with some friends. Noticed a slight fuel leak near the carbs. Upon inspection, the plastic hose barb had a crack and when I touched it, it fell off a little brass barb leading in/out of the carb. Theres two fuel lines with the same type of fitting and I can see the second fitting is starting to crack as well.
As a temporary means I rigged the fuel line straight up to the brass fitting - but its not a proper hose barb to say the least. At least the fuel stopped leaking!
Do these little brass pieces unscrew from the carb or are they pressed in?
Eric
You can get a used carb. for cheap.$30 to $50. bigger one too I think that's lust a 28mm, pwc today has a great classified section and a big X2 following.
