- Belleville, MI
Hey guys! Newer to the standup world but I'm going all in on this build. This ski is one I want to try and keep for a long time, if not forever. So I want to build it right and have it be my work horse.
Its a 1990 superjet that is stock currently except an aluminum handpole (factory length), intake grate, and aftermarket ride plate (longer than ideal for freestyle)
This is my plan for the build. Any advice welcome and any insight would be appreciated!
Motor:
I have a 1995 wave raider I just purchased with a 62T motor I plan to swap into it. Hopefully the swap won't have too many road blocks.
For now I want it stock while upgrading the rest of the ski. Later down the road I want to do a pipe, ignition, lighter flywheel, and maybe a head.
I assume I just need to use the factory exhaust from the 650 for now and port the exhaust side to match the manifold?
I hear that isn't the best motor for my setup but I got a good deal on this ski and decided to just go with it.
Hull:
Tray- kickers or diggers with new hydroturf. Maybe add foot straps depending on what I end up liking
Hydroturf on side rails for grip
Hull reinforcements
Front sponsons
Any recommendations for hand grips on the hood for tricks?
Dual sumps with rear mount plate
Foam block for hood
Hood straps
Handpole strap
Pump and Steering:
Worx intake grate
Worx WR315 ride plate
Intake stuffer
9/15 impeller
Maybe use the pump from the wave raider and have a trim setup? Not sure how that will work but if I can, that would be awesome. I will already be in the tray for the footwells so I wouldn't mind getting the plumbing done for trim cables
Stick with the factory nozzle?
OVP steering
Flat handle bar
ODI grips
RRP throttle lever
Again, any thoughts or insights are welcome. I will post pictures of the build and progress this winter as I get things done!
P.S. these pics were right after I took it out of the water for the season. Don't have a stand yet but I'm working on that. Don't judge the messy garage, had to do a lot of vehicle maintenance during the time I pulled it out of the water lol.
Motor:
Hull:
Hull reinforcements
Front sponsons
Foam block for hood
Hood straps
Handpole strap
Pump and Steering:
Worx intake grate
Intake stuffer
9/15 impeller
OVP steering
Flat handle bar
ODI grips
RRP throttle lever
