- Sequoia National Forest
That doesn't seem very likely, or most of us would be having the same problem.
Have you removed and inspected the plastic elbow at the top? It has a tiny hole in the side to break the siphon. Maybe it is clogged or damaged?
When you say once the line is clear of water it is fine, which would lead me to believe the tiny hole is clogged and is allowing it to siphon.
WINNER WINNER CHICKEN DINNER!!! Thank you mbrick!!! I just grabbed the plastic elbow and you are right, it has a tiny little hole that I never would have noticed, and it's completely clogged. Hoping that does the trick . . . sure would make sense. Thanks dude!
