1991 Kawaski X2
The ski runs good. I had it out on the lake on July 28, 2023. As far as I know, the motor is stock, except for a 42mm Keihin racing carburetor. Compression is just over 130 PSI in both cylinders (Which is not bad at 6,000 feet above sea level). It has an Ocean Pro ride plate and an aftermarket intake grate. Has a custom paint job that is showing its age, but could be touched-up. Needs a seat cover, but is rideable the way it is. Includes a homemade PVC stand and hitch carrier. I also have a few extra parts that go with it, including a pipe cone with a water fitting welded on to the outlet, milled head (don’t know how much was milled) and a new finger throttle. Asking $1500 OBO. Located in Colorado Springs, CO.
