- south florida
Howdy all!
New guy here as you can tell .. I have a 1994 blaster, It has been a good ski thus far, I do not have all that many hours on it and have not had any issues up until now.
It seems I do and don't have spark.. sounds stupid I know.
Here is whats going on.
I had the hose hooked to it to flush it.. didn't get to it that instant, wife decided to water flowers.. turns hose on, floods engine.. it wasn't locked by the time I got to it.. but there was water in the cylinders.
So.. i pulled the plugs and cranked it over for some time.... it spewed water and I feel I got "most" of it out.
Here is where things get weird...
I throw the plugs in, try to start it to clean it out and it fires... runs for about 4 seconds and shuts off.. then, wont start... So I pull the plugs and NO joy.. no spark.
I pulled the front cover over the fly wheel because I thought maybe some moisture intruded in there. I took the wifes hair dryer and placed it in there on low directed at the flywheel and left it sit.
Later on I checked it and there was a weak spark.. not nice fat and blue.
Could not start with the weak spark and the moisture still in the engine.
I pulled the box cracked it open and checked power to my coil.. it was 12v and "seemed" right.. I am NO expert on these electronics... I work on airplanes.
I tested the coil according to the example I found on the net and it tested bad.
OK.. good .. right?..
Just got the new coil I ordered.
Put it in the box reassembled and tested it.. Bright blue fat magnificent spark... GREAT! .. right?
OK insert plugs, prime each Cyl.. prime carb.. crank over to start.. crank some more, more.. no life.
Hmm.. pull plugs, they have a milky mess on them.. yep water.. but they also have NO F'N SPARK!
Slap 2 brand new NGKs on the wires and nothing... No spark.
I pulled the connector for the kill switch.. I even pulled the one for the starter and jumped it in case it was the kill switch and not the lanyard switch.. Nothing.. No spark.
So.. in a nutshell I am here to pick your collective brains about this issue.. Please bear in mind if you go into details about testing these components please explain it as if you were talking to a 5 year old.. I am not that savvy on these things.. airplanes have MAGS.. not CDIs and coils.
and my cars are not like these either.
I have read about testing some of these things but I do not understand the electrical terms and nomenclature of the parts involved.
That said.. I am not an idiot and will be able to figure it out with well written directions~!
I have a component that is failing.. obviously but I want to avoid spending 5 thousand bucks replacing parts until one works.
thanks in advance for any help or suggestions you may be able to provide.
