- Wasaga Beach
Unfortunately, its time to sell my pride and joy. I built this Blaster three years ago from the ground up and it has seen approximately 12h of use since it was built. It was professionally reinforced with 2 layers of 12oz biax. Professionally painted inside and out with an epoxy paint.
The list of aftermarket parts are as follows:
Dasa +5mm stroker 908cc motor running pump gas domes.
Dasa case reinforcement plate
Dasa billet intake with V-Force 2 reeds
Dasa billet flywheel cover
Dual Novi 48mm carbs
RRP carbon exhaust system
RRP/TBM light weight charging flywheel
2pc Solas 148mm Magnum pump
Solas 148mm stainless impeller
701 Air Down system
UMI steering system
Custom machined UMI adapter for fat bars
Blowsion Carbon Fiber D-cut ride plate
UMI finger throttle
Free Riderz quick start
ODI grips
Pro-Taper handle bars
Carbon fiber coupler cover
MSD Enhancer
Jet Works water flow restrictors
Thrust 3 gal gas tank
Air Time Products Torrent intake grate
Hydro-Turf mat kit
Hydro-Turf shaved seat with cover
Hood shocks
Blowsion bypass and bilge fittings
Blowsion 3 position bilge switch
Rule bilge
Dakine foot straps
Tau-Ceti flame arrestors (please note, the carbon flame arrestors in the pictures will not be included)
I’m sure I’m missing a few parts but you get the idea… Custom anodizing throughout. I am a perfectionist so; this ski was built with a lot of consideration and care. Buyer will not be disappointed. Located in Barrie, Ontario, Canada
Sent from my LG-H873 using Tapatalk
701 Air Down system
UMI steering system
UMI finger throttle
ODI grips
MSD Enhancer
Hydro-Turf mat kit
Hood shocks
Rule bilge
Dakine foot straps
