2 questions??
air blair
you are the reason
Need some fittings for head but I guess I'll be running it.
Air blair cell
air blair
you are the reason
Tossed some fittings on this head, ran what I thaught would work but the thing is my cylinder and head are pretty damn cold when running. Lots of thaughts running here.
Air blair cell
Roseand
The Weaponizer
Wisconsin
I've used a cheap laser temp gun with good success believe it or not.. But temp strips are nice too.
air blair
you are the reason
I never gave two poops for hoe warm or cold my engine was. I always just hooked up dual cooling and ran it but this is one ice cold running setup. I imagine you can dial in the ideal heat range. Hell I just want it to act like an Ada plug and play. I'll just restrict some poop and run an ice cold head as long as I can get the cylinder to that temp that is ideal.
Air blair cell
air blair
you are the reason
One pump line goes to manifold and exits out of both cylinder pissers on top of head seperatly from the head cooling which enters on pto side labeled in and out stator side which I loop under and into bottom of headpipe. I'm going to run smaller barbs off top of head. See how that goes.
Air blair cell
So the head has two separate cooling jacket parts? Maybe you only run the dedicated head cooling in the summer? Seems strange, but I can't see the pictures right now at work. Probably linked from facebook...
air blair
you are the reason
Ya kinda weird head. You know you push sand through your pump cooling at times. This will push it right around the domes and what not so restrictors need to be big enough for sand to exit with enough flow also. Maybe I'm thinking to much about it. Cold seizure comes to mind on cylinders if not ideal temp is not met. I was tuning my carburetor with hood off riding and wasn't sure if I was getting a proper read on tuning as it warmed up and cooled down so quick. My water temp is getting cold here in the lake apx. 50*f
Air blair cell
I bet the theory behind that head is to running the cylinders warmer so you don't get seizures, but run the domes as cold as you can to avoid or reduce detonation with higher compression.
