- Texas
I love my single trailer conversion. Its a Triton that I bolted 2 4x4's across to act as out riggers for the 2x4 ski bunks to bolt onto. The trailer is very small which i like so the skis sit overtop the wheels and I've been trailering hundreds of miles this past summer with just 1 ski on the trailer while the other ski is getting a maker over. I was nerviness at first but haven't ran into any issues. If i were to do it again I would make the center bunks on each set a bit closer to each other so i could run 1 ski right down the middle or 2 up on the out riggers. Because of the wooden 4x4's I can also bolt all my eye bolts thru it and get all my tie down strapping points perfect. And there is just enough room for a 3 up fuel jug rail. For the size you cant really beat it. I'll have it at SFF in a couple weeks if you want to look it over.
could you take a pic or two? I'd be interested in seeing your setup as I have something similar but have not finished it.
