- New York Crew
2000 SJ super clean hull
Cut to -2.5"
XFT Carbon Surf layup hood
Blowsion Tubbie Destroyers
Here she was in January before ripping into her.
![IMG_0735[1].jpg IMG_0735[1].jpg](https://www.x-h2o.com/data/attachments/109/109315-c8fe55b47a6501b68394b5df855fc369.jpg)
I decided to keep the Red anodized parts and go with the theme but the superman blue and red had to go.
My build list of things I want to try this year:
Dasa PV motor, 89mm bore, 10mm stroke
Porting, trenching, epoxy and assembly by Dasa
One or two tricks inside for longevity and performance
Zero light weight 62T flywheel
Boyesen RAD valve intake system
49mm Full Specs, new 2012 style
Thrust air box billet adapers
Thrust hood hooks
New MSD enhancer for now. Surf reliability, thanks guys for reminding me!
Debatied between the FP Mod and the Power Factor. Decided to go with Mod for tank and surf. Ported to 50mm and clearanced by DASA.
More to come on that as I decided to buy a PFP w/waterbox. Just need a tank and mounting straps. I want 4 gals for surf.
Skat 2" set back Mag 144mm with 9/17 pitch, still tweaking this
Bored nozzle 86mm
Pro Tec steering nozzle
New OEM cables, steeering and SN throttle
New OEM starter and Bendix, cables, etc
JSS coil
Cold Fusion Coupler kit with blue doughnut
New OEM Mid shaft
Jet Dynamics intake grate
Stock cut short ride plate
RRP billet pole and steering, 50mm riser bars, chin pad, etc
Odi Ruffians
Fast Elements new 1" forward 1" down pole mount.
Stock water box, to keep the natives friendly
RRP footholds
Black Diamond Hydroturf
Brap Strap
Limiting rope
Thrust Trim kit
Custom made in pump cavity scupper ball
Lots of Carbon, tray, XFT hood, RRP pole pad, Pancake Pete foothold, reinforcement in tray and all sides, nose etc.
Paint by Zeon's Automotive, i didnt know it was going to be this nice on the bottom, so he also supplied me with a street bike tire for beaching it on
Vinyl work by Redrocket on the boards
Cut to -2.5"
Thrust hood hooks
Bored nozzle 86mm
JSS coil
New OEM Mid shaft
Odi Ruffians
RRP footholds
Brap Strap
Limiting rope
Thrust Trim kit
