w-nut
x2 nut
- christchurch new zealand
well i managed to pick up a completly standard 2006 x2 two weeks ago for my new surf boat and play boat at the lake . i rode it like that for the weekend to get the hang off the thing and then the fun started. i had a new engine sitting in the garage that i was going to put in my old school x2 but thought it would be fun to drop it into the new x2. so out with the old and in with the new.
new engine stats for now are
standard carbs
v force 2 reeds
ported cases
new hot rods crank rebuild with ceramic crank bearing trued and welded
cylinder bored out to 830 cc
r&d 27cc girdle head
fpp blaster limited chamber
wax infernal ignition .
wile i had the engine out i also removed the water box and tank so i could grind all the extra glue off the bond rail , fit a bildge pump and new water and fuel lines, duel cooling and a duck bill.
the frist pics is how it looked before, the second pic is the new next to the old. 3rd and 4th pic is the old engine out
standard carbs
v force 2 reeds
ported cases
