2009 revived 96 RN With Team Scream Love!
CarFanatic
Fiberglassing Newb
Cincinnati, OH
man flat water rolls>! jeez I"m not that skilled.. one day hopefully.
Ya hopefully end of the season or so, I'll get the bottom fixed, I'm just obsessive like that. Cant wait to ride it. I fired it up the other day, one blip and that thing revs like nothing!
Conquistador
B-Saw
He scratched the bottom! :shocked: I wouldn't take that kind of bad customer service! :rant: Instead, you should ask for a refund & send the ski to me for proper disposal. :wink:
Ericfox
Do it twice?That's DooDoo
14/18 hooker?
Dave recommended a 12/18 for a 860cc 8mil lamey with about exactly the same bolt-on and pump setup as this otherwise.... seems like most bigbores are using 10/16 hookers... and limited stock setups are using 9/15's....
Sure there's a reason why the 14/18 is working here... why? Thanks.
IKSTEJ
BOGIE
Region 7
14/18 hooker?
That little 735 is making some power:)
Our 8mm 802cc requires a tbm stuffer and a 15/21 to hook up.
A 144 mag would be the ultimate. But the TBM stuffer is getting it done
CarFanatic
Fiberglassing Newb
Cincinnati, OH
well I got to ride it yesterday!! Ski Rips!! IT looks bad ass, It sounds bad ass, only problem is I"m not bad ass.. haha.. I got alot of practicing to do this year, but I"m very very happy with the ski!! I am so out of shape though! man I'm sore today! Cant wait to ride again! I need pat to teach me those flat water rolls!
CarFanatic
Fiberglassing Newb
Cincinnati, OH
anyone have tips on positioning the b pipe so it doesn't rub the hull or gas tank? I figure with the reinforcement that takes up some room, I jammed a piece of turf in between the tank and pipe, but I"m worried about it rubbing on the hull.
Ericfox
It barely hits the hull on every sj hull Ive ever seen.... dont worry about it... if it ends up rubbing it too thin ( I doubt it) then you can just build it up again with glass or carbon in 10 minutes...
Ericfox
didnt xscream send it to you that way? if they built it that way I assume they tried to clearance it as much as they could....
Id run it and keep an eye on it... doubt its going to cause any problems... and Radney is only a phone call away... without seeing it in person there's no way to see just how bad its fit in there.... I dont think they would have sent it to you if it was going to be a problem though...
its a tight fit for sure....not much you can do outside of beat the outer edge of the pipe flat...I defintatly woudlnt do that unless it WONT fit..
worst that will happen is you'll rub a wear spot into the carbon over time....
If it were me I woudlnt worry about it.......we calipered the exhaust tract last night on mine and it turns out it WILL fit into the F1 pro :love:
another -30 lbs :cool2:
