Super Jet 2013 Superjet and Mods - Comment Welcome
Just bought a 2013 SuperJet and Here's a list of Mods for her.
First shipement has arrived from RivaYamaha and the parcel is currently sitting in customs. Hopefully I'll pick it up on Wednesday. Here's the shipment so hopefully by Thursday it should be in the Hull.
1 x Reed Valve Set, V-Force, YAM, 701/760 2 cages
1 x Bracket, BILGE PUMP SJ 96+
1 x BILGE Pump Kit (Deluxe)
1 x Scupper Valve, One Way, All Stand-ups
1 x Pole spring
2 x Riva Carb Adapters
2 x Riva Pre-Filters
2 x Flame Arrestors
This order and will be the second shipment. The Factory B-Mod Pipe is only available in February so hopefully by end feb all will be in.
1 x Factory Limited Pipe
1 x KICKER FOOTWELLS, STAND UP
1 x Blowsion MAT KIT,96+SJ, KICKERS
1 x HEAD SHELL, GRDLD, 701 / 760
1 x GIRDLE H/W KIT, 701 / 760
1 x DOME, 701, 35CC, 81MM, ADA
1 x ADA ORING KIT 701/760 CYL HD
1 x O-RING KIT PS-2 HEAD, 2-CYL.
1 x Dual Cooling, YAM SuperJet
1 x BULKHEAD FITTING, 1/2in ID ALUM
1 x PRO FLOW VALVE, 3/8IN
1 x Impeller, Skat-Trak, 144mm SWIRL, 12-17 Degree
Any comments and Suggestions welcomed
Thanks
Mufassa
1 x Pole spring
2 x Flame Arrestors
Thanks
Mufassa
Ive heard the kickers are very uncomfortable although i have never tried them. I went with the tom 21 footholds that accept 25mm pad on the top and bottom. I think ill like these because ill be able to shape the foam how i want it. I did have to modify them a little to get them to fit properly due to the fact that they were hitting the exhaust pipe and the gap where you rivet or screw them down was huge. Other than that they were built well. Theyre going in a 2010 sj. Other than that this ski is gunna be sick.
Ohio
2 x Flame Arrestors
Hell NO IMO!
I would have left the stock reeds alone for a long time too....just my opinion...and you asked!
Hi Madmat.. yes I believe the stock reeds are very good. I ride MX Bikes as well and one of the first things I do is install V-Force Reeds 3 on the YZ 250 just to clean out the bottom end and make it hit harder. Any reason why you would leave the stock reeds in. I have not installed them so I can change my mind. Let me know what's behind your reason for using the stock reeds.
I'll be doing the upgrades one at at time: So Carb Adapters / Pre-Filters / Flame Arrestors first. After each upgrade I'll be taking her out for testing and I'll keep records of performance increases..hesitations and or bogging etc. I'm hoping to build up a reference sheet that's I'll post on the forum.
:):):):), done and dusted. The kickers are being manufactered by blowsion as we speak. Taking the Blowsion mat kit as well with the kickers. Any idea why the Kickers are uncomfortable or is it purely just a padding propblem or issue with the design/shape
Just wanna tickle some grey matter here. (riding at sea level)
1. The Flame arrestors / Pre filters should lean the fuel mixture out
2. V-Force 2 Reeds / Should make the fuel mixture richer. (So those two should more or less balance each other out
Wish we could poll here!!!
kickers are fine....footholds are all about personal preference, just the same way as some guys like to :):):):) fat chicks
you are overthinking the reeds and prefilters........just leave all that stuff stock and save your $$$
Thrust Innovations for ALL of your needs..the other companies will kill you with shipping costs
Ohio
My reason for running stock reeds is you will not feel a noticeable difference (actually zero IMO!) for the money $spent....let alone wrenching for no reason. (not my thing!!)
Anything other than stock flame arrestors at least 2 downsides IMO: 1 they fall apart 2 they let water in 3 the pre-wraps need replaced. (and they still let water in!)
Stock is bomb proof and very very very good at keeping water out.
Just my opinion but if I ever get a brand new superjet :love:I will do what I know works for me:
13/16-3mm solas, 85mm exit nozzle, MSD Enhancer, B pipe, shorten the pole and add kick ass steering, beat it to death!
Or some other variation (depending on if I was riding flat or waves) of thrust and handling.
^x2...stick with the stock flame arrestors...I just changed to 44mm carbs and am going to use the stock F/A that came with them.. spend your money on good mods like a B pipe and hooker prop..
djraider700
lol wut?
South Jersey
Upgrading the stock steering should be the first thing to do. Like, don't even ride it until you replace the cable with a 96-07 one or a schmity1 cable. Steers like a container ship stock.
