- Toronto, Ontario
Great beginner freestyle/learning skis and tons of fun. Just time for me to upgrade. ski is tuned to run pump gas and runs great.
Aftermarket “Superjet based “ Air time products axis hull
AXIS is wider for stability this also allows for more room in your engine bay
AXIS shorter and with more front rocker all enabling it to flip and roll far easier than a Superjet
AXIS is more than capable of surf riding at competition level
AXIS Pump area is all as the pre 08 Superjet.
AXIS tray is wider at the middle to rear
AXIS Rear top deck quarters designed to dissipate the side slap impact on failed landings
gel coat finish
All hull inserts are brass
Polyester GRP & Carbon Kevlar and Epoxy reinforced
Rideplate
Dual cooling tubes fitted
Trim tube fitted
Exhaust tube fitted
Scupper
Empty Hull weight 43kg (95lbs)
- ATP built Axis superjet style hull
- Wamiltons light weight carbon fibre hood
- ATP billet adjustable lightweight pole
- ATP mini steering and straight bars
- ODI rouge grips
- Umi billet throttle lever
- 790cc CTP built engine. 190 psi in each hole
- Dual 44mm mikuni carbs
- Riva throttle cable wheel
- R&D intake and Vforce reeds
- Blowsion flame arrestors
- Factory Bpipe
- ATP waterbox
- 144 OEM pump
- 9/15 hooker prop
- ATP freestyle nozzle
- RRP Ninja footholds
- ATP adjustable intake grate
- Full size superjet tank
- ATP billet centre battery tray
- Hood straps
- Bilge pump
Extras I have
- 144 SBT pump brand new
- Modded reduction and trim nozzle
- Cart tank
- Spare hydroturf
- Optional green blowsion flame arrestors
located in Toronto, Ontario
10.5k CAD or 8200 USD
Can ship as well
gel coat finish
Rideplate
Trim tube fitted
Exhaust tube fitted
Scupper
- ODI rouge grips
- Factory Bpipe
- ATP waterbox
- 144 OEM pump
- 9/15 hooker prop
- Hood straps
- Bilge pump
Extras I have
- Cart tank
- Spare hydroturf
Can ship as well
