2015 Phantom build
Some might think so. I don't. A 760 uses them and that's only 140cc less. It's very easy to make those run rich so I don't think that it will have an issue delivering enough fuel to a 900. We shall see tho. Like I said I'm trying to keep the total cost under 10k. 2k on carbs is crazy to me. I could buy gas for 100 hrs of practice for that price.
SpaceCowboy
breaking something
Yea carbs are crazy expensive when you have to buy an intake and reeds as well. Few good deals on scream 46's on here as of late which I've ridden a 900 with that setup.
Can't wait to see this thing hit the water!
Schmidty721
someone turf my rails
WI
I have a set of X-metal modded 46's on a boyeseen manifold that would be mint on that engine... It won't cost you 2k either ;)
It's not about enough fuel and running rich, it's about allowing the amount of air to flow that the engine wants...
Stockton
I ran 44's "R" s on my Lamey 863cc and it worked fine, good fuel range too. I switched to FS 49's and I got a little more height and lot less fuel range lol.
If a 61x 701 gets enough fuel and air from air single 44. I highly doubt 200cc more engine displacement is going to need more than double the airflow. I appreciate yhe opinions tho. Always welcome.
The breather holes are smaller. I already have a ski with Xmetal pole. And 2 other skis with black rn poles. I want to color coordinate this one best I can. I'm doing the blue camo turf, and a pole with blue tubes. Most likely going to go with blowsion new setup. Thanks for the advice tho.
River Rat
Squarenosed
USA
Very nice phantom. Can an oem or any hood latch system be used on these hulls? Motor mounts look back , does it use a superjet Midshaft or an 1100?
