- HUNTINGTON BEACH CA
you installed the pump last? how did you check alignment to your mid shaft? sweet lookin hull btw, always loved solid white
He's probably busy with work. I'll just say. I rode it and wow that thing is great! Once you put in a few minutes on it you get adjusted to it super fast. It's super nimble and stable, the splash guard keeps water out of your face. It doesn't do anything you don't want it to. The hull is responsive to your every move. It doesn't ride nose high like other hulls I've rode but when you want it to come up it does. He would've flipped it but on the second day of the trip the bearings in his Mag pump went out.
Here's the eliminated waterbox
Yea maybe I should off my b pipe while there a hot comodity hahaLooks like its time for a PFP
Why not run the smaller etx9 in the rear battery tray? Also, try an H20 Designs or Xmetal waterbox...they should work fine. (If you want to run a waterbox)
Getting greenHere's Casey hulking around his complete ski![]()
