2016 Daytona Swap Meet Thread
Ducky
Back in the game!
Charlotte, NC
I have a few things I can bring:
- SJ hood latch assembly. In good shape. $30
- RRP Pole Tubes. Full Length. Brushed/Polished finish. I used one of the tubes as a long exhaust tube in my ski for the summer, so it will need to be cleaned up on the inside, but they are both in nice shape on the exterior. $40 (Cheap because of the cleaning necessary.)
- 61x stator with quick connect harness from JSS. It is pretty dirty, but it works. $30
- OEM RN throttle Cable. Great shape, minimal use from what I can tell. $40
- ADA billet throttle wheel. I hit one of the throttle holes on the wheel with a drill bit when I was drilling out my throttle cable holder, so one of the holes has a little ding, but nice otherwise. $10
- Stock Dual 38 Airbox. (Top, bottom, and screens...dont think I have the hardware.) $25
- Stock Yami Coil. Working, but I would put new wires and boots on it anyways. $25
PM me or text/call me at 607-341-3571. I can send you pictures, but I am leaving around 4:30pm today for Daytona, so do it before then.
Picture of the RRP pole tube used for an exhaust tube.
Lets see here.. I have
62t red noz,trim ring, and steering nozzle
62t stator
62t flywheels x2
new rule bilge pump 500gph
2 62t cdi's
62t trim ring
hood latches
760 intake manifold with reeds
some other set of reed cages with carbon reeds
small billet battery box
stock RN water box out of my 2014 SJ
Carter B Ride plate, Carbon/composite, D-cut
coil
Oem motor mounts x2
Will trade for freeride t shirts, raffle tickets, gas. I'm coming on a limited budget and wont be able to splurge hahahahaah
Call or text me 757-714-0006, or find the only Kawasaki TS on the beach
