- Ahwahnee, CA
2016 Rickter Edge FR, fiberglass. Built by Taylor Curtis at TCFreeride. Most parts brand new at time of build. Very few hours on the build since taking delivery in March 2016.
2010 freshwater only 61x/62t stock low hour motor.
New ADA girdled head
Immaculate dual 38MM mikuni carbs (essentially new take offs from an '08 superjet- JetWorks tuning screws added)
New Hot products flame arrestors
New ADA Throttle drum
New factory B Pipe (mod)
New Jetinetics flywheel
New MSD enhancer
155 OEM pump with new skat impeller
New Rickter intake grate
OEM style water and fuel lines
New OEM throttle/steering cable
New Yuasa battery with Cold fusion battery box
New Cold fusion gas tank
New OEM yamaha mid shaft assembly (bearings, mid shaft housing,shaft)
New OEM yamaha motor mounts
New PJS throttle lever
New Rickter trim and trim lever
New RRP Straight bars
New ODI ruffian grips
New Billet RRP pole
New OEM start/stop switch
Bilge set up
Thrust Scupper (it doesn't leak like OEM rickter)
New X scream waterbox
New OEM gas tank and battery straps
The ski is pretty flawless. I'm not looking to ship at the moment. I am looking for 15k. Reasonable offers accepted.
New MSD enhancer
New Billet RRP pole
Bilge set up
