Captain PegLeg
GJP
- Villa Rica, Ga
Selling a very nice Rickter Edge carbon hybrid compete ski. Boat was built mostly new parts sourced from Jetmaniac or LPW mostly. I will try to list as accurate as possible. The ski itself is in very good shape, with just the typical wear marks on the bottom. Turf looks good, graphics and gel coat look good, the visual textreme carbon is beyond sexy! Ski starts right up and is ready to go to the surf or lake! Asking $14,900 and can ship or personally deliver.
Call or text Robby at 770-883-8732
-2016 Rickter Edge FR Hybrid Hull with visual textreme carbon
-Billet Lightweight RRP handlepole
-LPW Ported 735cc 61x engine. Cases and cylinder worked.
-Wossner Pistons
-ADA High compression girdled head
-OEM 155 Pump with solas prop
-LPW Lightened OEM Flywheel
-Wetjet intake with Boyseen reeds
-48MM blackjack carb
-K&N Flame arrestor
-LPW Ported B-pipe manifold
-Limited Factory Pipe B pipe
-Jetmaniac waterbox
-MSD Enhancer Ignition
-OCD Solutions Surf armor cable kit
-Kenny Keepers
-Cold Fusion 5 gal tank with internal fill
-Fuel tank cradle
-Aluminum battery box
-Flow control valve
-RRP Intake grate
-Billet Throttle wheel
-RRP Steering
-RRP Riser Bars
-RRP Finger Throttle
-ODI Grips
-Blowsion steering cable
-OEM Yamaha S/S switch
-RRP ninja handle pole pad
-Rear footstrap for surf stance
-Wossner Pistons
-K&N Flame arrestor
-Jetmaniac waterbox
-Kenny Keepers
-Fuel tank cradle
-Flow control valve
-RRP Intake grate
-RRP Steering
-RRP Riser Bars
-ODI Grips
