- Los Gatos, CA
Hello,
I see the mixture screws are capped on my new 2016 SJ. Looks like I need to pull the carbs from the engine, and separate them, in order to be able to drill out and remove the 4x caps?
After 5 hours run time I see the MAG side is fairly rich on the high speed based on the plug and piston wash so I would like to check all screw positions.
Is there just one paper gasket under the carbs that I need to replace after pulling them? I'll order the OEM parts before I begin.
Atlantic jet sport says with their t-handle screws the choke needs to be removed. Theirs look like Pro-Tec rebrands, so is that also true for the Pro-Tec screws? I do not want to remove the choke.
Will the Mikuni genuine 'cross bar adjusters' work with the choke in place?
If I just order the same screws from my '99, will they install in the 2016 carb? Those don't require the choke to be removed and work fine with a screwdriver.
It looks like the only clearance issue is the mag side high speed screw, where the choke mechanism rotates by. The others are wide open.
