- Floridapunk
Looking for an aftermarket surf hull with at least a 155 mm pump.
To trade is a very low hour 2019 super jet all stock what I had modified is the steering column and some of the whole bondline has some drill holes in it the hull is in good shape I've added soonsons that I can removed and it's back to stock. The upper hull is modified. The value in this one comes in the mechanicals 100% stock the hole has been body worked and modified but it can be brought back to stock on the lower hull. If interested pm.
