2021 SuperJet Steering Cable
TN
Does anyone know if the stock skis have the pre 07 steering cable?? I got the Mac boost carbon poles and went to move the top bracket couple holes back and had to move them back cause the steering cable was to tight. anyone know if I switch out the steering cables would that give me the extra length so I can move the bar postion back??? I wanna say the throttle cable felt like it was short also and didn’t have the enough length to be able to turn the bars
I put in a 90-95 SJ cable. It's longer overall and has better throw than the 21 cable. I also installed an RRP pole but you'll also need to move the fixed point in the handle pole forward. I also needed the OEM heim joint to extend the cable at the nozzle.
TN
I’ll prob switch out the steering cables
Kohldanielzimmer
Sierra Nevada Runoff Rider
Ahwahnee, CA
I use 06-07 cable but squarenose cable is probably better as the first gen roundnose cable requires fittings on both ends to be screwed out pretty far.
JetManiac
Stoked
orlando
Blowsion sells the cable and bracket to run the older much better cable!
JetManiac stocks the cable and bracket. Bracket is for the stock pole. If switching to an a/m pole then bracket is not needed.
Add a cable extender.
