300/440/550 212 HP 650cc X2
750SX
DO IT
Palmyra
Using a titanium alloy bit for my drill I CNC'd an impeller using precise motor skills and a 6,000 RPM Black and Decker multiple axis, variable speed, variable bit size, brush motor powered hammer drill. Using TLAR and some common enginuity, it was quite simple to CNC a simple variable pitch impeller out of plastic, which will not only act as a lightened flywheel, but the pitch flattens at high RPM for better low end, while it expands during lows, so you get a high speed idle capable of maintaining plane, and when you want to get into the power, the torque is multiplied by a factor of about 5.6. This number is an approximate however, and with a few different materials I am working with in the future, this number is expected to GROW!
an interesting concept there.
Your plastic impeller is inferior to my ceiling fan in so many ways. Mine is cast zinc and wood, yours is just plastic.
RiverRat
Louisville, Ky
Very interesting!!! :bigeyes: Nice to see new developments being made and I am anxious to hear how this thing runs. Looks like you have the tools and talent at your disposal to make big things happen. :biggthumpup:
WFO Speedracer
Alabama
I used 100 cases of jb weld to encase my jet pump then bored the pump out of it with a well drilling apparatus set up with a briggs and stratton direct drive .I am using a special dual helix conversion spiral for the stator section machined out of unobtainium and a special impeller used by nasa to empty the flotation tanks,it should be quite lovely really.
750SX
DO IT
Palmyra
the tree sap that i have been using has a higher psi rating. OWNED
I will be removing all of the foam in my ski and replacing it with pingpong balls
WFO Speedracer
Alabama
I started to do that but then thought the hull would bounce too much so I used packing peanuts instead.Now it rides smooth.:haha: :haha: :sneaky: BTW I think you will have problems with the tree sap immersed in water whereas JB is waterproof,don't junk it JB it.
The preceding has been a paid for advertisement by the JB weld corporation,warning do not try this at home ,use at your own risk,the results are not typical,your results may vary.
dbrutherford
Parts Whore
Fairmont, WV
Courtney huh? I see them bidding/buying/selling a lot lately on eBay. I noticed one auction where the high bidder was korey_n_courtney. Then the high bidder at the time was kalen_n_someone's_mommy, I forget hte other name. I looked at the mommy's feedback and found an auction where they were the seller. The city was Escondio, CA. Guess where Korey and Courtney were selling from? Doesn't take a PI to figure that one out. I felt like reporting that tid bit to eBay just to get them in trouble, but I have never had dealings with them so I let it go. If someone they ripped off wants to then.... do some searching and you will find all the answers you are looking for.
As for X2 Cartel... I ma betting Waterhawk too. Where has he been lately? Exactly!
DBR
