24-7 backflip 7mm lamey build
hangtime
Speak up ,don't kiss azz
I bet i can post pics of what your case porting looks like
I would paint the case silver if it was my engine
Since it's Paul's first billet cylinder I doubt that .
Ben ,you want to ride Tuesday ?? I'll be at my dad's tomorrow and working Monday .I tuned my boat some more today and it's running much better .
I need to do something about that hole I carved in my hood so it wouldnt rub on my airbox ,it pours water right onto my carbs when subbing.:banghead:
waxhead
wannabe backflipper
gold coast
It might be pauls first billet cylinder but the cases are still std yamaha
Basically every one ends up with the same in the cases when they start doing hp engines
If it doesnt look close to this then i would be asking questions
When are you doing the x-2 conversion on the superjet??
As far as the case porting,ur close but not quite.First off my case figers are still there.And yes its that style,but there are many subtle changes between builder to builder.
Big Kahuna
Administrator
Tuscaloosa, AL
Paul has been running ADA billet cylinders for years.
eel
Our home is girt by sea
I like the last two cases. I don't think either are my work but they are VERY similar.
eel
I stand corrected, they are my work. I just don't recall filling the "fingers".
Wax informed me they are an older set.
:lmao:
Bun doesnt remove the fingers on his strokers.There has to be a pro/con on this?Ive seen builders doin both styles....got me on wich is better.
