I went with this setup cause it was the least trauma to do,A blaster shaft just happens to be the precise same extra length as the extra wear ring over a sj shaft.It would be better to move the inlet back as well,but this is a easy fix to gain more steering and trim leverage,as well as keep the pump loaded longer as you come out of the water,I got to ride bolte fr2 with the pump further back and really liked the pump setup position,this is just a $6000 cheaper way of improving a sj hull than replacing it,lol.If a 1 inch mag setback makes a diff,this will only make 3 x more diff,as I could care less about high speed hookup I just want more hook at the last moment on reintrys and then more area in the pump to compress whitewater landing in the foam.
I will be trying this with a 142 setback mag as well,Chris is gonna make a custom shaft for me to do it,this will be a 4 inch setback and have the benefit of the higher mag pump pressure.Im sure this will compress whitewater even better.
Tubie.. your setup makes sense for racing where you have rules on how far the pump can be out the back,but in this case freeride guys can use the entire wear ring and use a b1 shaft,with a stock pump rather than having to to make a custom shaft for even less result,If you can make one of the steering cable inserts a little longer Id like to try that,just not sure if there is room with the cable to move it back 4 inchs,so im looking at a reinforcing sleeve to put over the whole cable and extension as well.
waternut,thats the same thing I have done,but its still more leverage put on the cable further out from where it over laps,some reinforcing is in order im sure
