300/440/550 440 superstock coffee table
Was going to turn old 440 hull into cooler for beer etc., but my one year old son decided it was fun to play on - so now it's part of his play equipment. Still doesn't stop him from getting on my SJ whenever he is in the garage though
demolition_x
Not After Fame & Fortune
no this is a big cooler....
had this on our fishing boat.
holds 320 quarts.
pickup truck for scale
djyox
Old school -not by choice
Twincities, MN
I want one of those sooo bad, you could fit at least two dead hookers in them!
I saw on on the side of the freeway, spun around to go grab it, and the whole bottom was blown out of it.... awwwww shucks!!! Guess its to walmart with the $80 or how ever much they are... Not the same one as you posted, but a big mofo none the less....
Mouthfulloflake
ISJWTA member #2
NW Arkansas
I designed a TEC ( peltier) cooler for my dock, using lake water and a 12v pump across the hot side ( copper plate and tubing instead of heatsink)I can easily get the cold side to 0 degrees.
the problem, it needs 8 amps at 12V to do that. ( and we stay down there 12 hours a day)
in the end, I still carry ICE.
kingnothing3
give me fuel give me fire
haha funny story(you might have had to be there) but we brought a cooler like that on our canoe trip so that we wouldnt have to have a bunch of smaller ones. but to have beer while we canoed we needed a cooler to keep them cold. well we straped the damn fridge sized cooler to the canoe my cousin and I were in (since being standup riders we had the best balance). bad idea!! almost lost it a coulple times:bigeyes: proud to say that no beer went to waste that day. and if one did i just dont remember:friday:
surfjetlouie
R.I.P. 11/27/2008
I was looking to make a shop light by using the pole from a 550 Kaw and the pole bracket with the spring and put it to the wall so i could swing it up or down then instaling a halogen light inside the pole where the turn plate is.
well never done it to many other project.
also using 4 pole from 550 and using them as table legs with the bar and grip so a glass top will sit on top of it using the leg on a criss cross patern. never done it.
