SXR 44mm carb
i have a set of 44 do you think i will get more power or i should stay whit the stock one -wet pipe, tbm flywheel ,boyesen reed ,advent ignition , 190psi comp
I don't think you'll get much of a gain going to SBN 44's. Others may disagree. You'll notice much harder acceleration going to SBN 46's and increased fuel consumption but it seems the stock I series carbs already use a lot of fuel. You really want a change go to 48 Novis, Full Spectrum orBlackJack carbs. Maybe others will chime in with their experiences.
Agreed, I had a set of 44's and I really liked them. Until I bumped up to a set of 48 novis. It is not a night and day difference. But it is something fairly noticeable. Keep in mind with the 44's you are going have to go with an aftermarket intake mani
