Huh ?I could tell the difference the solas mag made with my machine just idling on the trailer. I'd recommend one to anyone sportin a stocker.
The new stator will make your ski a dyson. lolJust bustin balls! Its a blizzard here!
Air thrust!!???
Don't confuse cut back with set back. Cutting back the prop is done to get the blades closer to the vanes. Optimal cut back is as close as you can get to the vanes, and then adjusting pitch and such from there.Going from 6 to 12 vien is a great improvement, the 400$ solas's are a great bang for the buck mod, not sure what the optimal set back is but I put one in my 95 and its awesome!
Not confusedDon't confuse cut back with set back. Cutting back the prop is done to get the blades closer to the vanes. Optimal cut back is as close as you can get to the vanes, and then adjusting pitch and such from there.
Setting back is moving the entire stator vane section and prop further to the rear of the pump assembly.
Cutting prop is better but different washers is a great way to tune and find out exactly how much to cut and that's exactly why I said I wasn't sure what proper PUMP SET BACK was, still not confusedYou said you set your prop back 3mm. I just think it's a little confusing because set back typically refers to the placement of the vanes and hub within the stator section. By removing that washer behind the pump, the effect is the same as cutting the prop back. And cutting the prop is probably the better solution as that washer is intended to help protect your pump seal...
