- alberta, canada
hi guys. I rebuilt a 91 piston port 550. Everything is good I just confirmed that timing is at zero. It's getting amazing amazing spark, turning over extremely fast. I've put fuel down the carbs (race fuel) no fire. Not even a sputter. Not even with carb cleaner. Now I checked the compression and I'm at 90psi. The reason I did this rebuild is because buddy said his motor seized. After ripping his motor apart and finding nothing wrong I discovered the pump was seized. No biggie rebuilt the pump and decided to powder coat the motor and make er pretty. Buddy said ski ran great prior to pump seizing so I decided not to bother with piston rings however I put all new sbt gaskets on it. And now nothing. Any help or suggestions? Is 90 psi just to low. I know stock is around 120-130 I was just hoping once I got the ski to run maybe the rings would seat a little better
Thanks.
Thanks.
