5mm/8mm stroker crankshafts??????????
I know how they work.Do u buy them new or do you modify your own to 5mm/8mm and do you need a new crankcase...?? how much is it??:dunno:
thanx in advance!
tricky1
XXX
Alabama
thanx in advance!
You can not modify you own. you can buy new, but they are very pricey.$1300+
to run a 5mm very little to no mods are done to the case.
6mm to 8mmm and up require case mods to work.
6 to 8mm set ups don't come cheep$$
Jr.
Standing Tall
Staff member
Hot-Lanta
Yup, What tricky said!
waxhead
wannabe backflipper
gold coast
i have a 5 mm stroker cranks thats almost brand new
and also a 6 mm thats been stripped down and has been cleaned for a rebuild
i am going to be selling these soon
if you want to buy it then now is your time
Prem1x
Tinkering obsessed
Austin, TX
tricky1 said:
You can not modify you own. you can buy new...
But you can send off cranks either trashed or in good shape to have stroked, right? You don't necessarily have to buy another crankshaft if you already have one to have it stroked.
tricky1
XXX
Alabama
No you can't just send off a standard stroke crank and get it back as a stroker.
tricky1
XXX
Alabama
Let me rephrase that.
You can't turn a standard stroke crank into a true billet stroker.
On the other hand you can have the big pins replaced on an OEM crank with offset ones to add additional stroke. Not something I would run, but it is an alternative.
Prem1x
Tinkering obsessed
Austin, TX
Well, no one said the word "billet" yet, till just now. I think off-set 5mm OEM cranks are perfectly viable and reliable options. Any longer than that and I would only consider aftermarket options.
waxhead
wannabe backflipper
gold coast
i wouldnt run a welded re drilled one
the rad is a much stronger and better balanced crank
