Polish jet pilot
4aces4aces4aces4aces4aces
- Warsaw, Poland
Guys I totally agree that listening to folks here is a good thing and I always do it and anlayze / compare. About "Race keyword': a guy who build engines for racing, or for whatever elese sets them up for racing by calculating port timing. He can time your engine as needed by doing some serious math (not my league at all). So he knows wehen and how power is delivered and how it should mix, burn etc (sorry for shortening all this). About sleeves: he is old school (really) and he said he could mahe a cylinder sleeve (he makes them for his boats, as well as cylinders, props, pumps, pistons, you name it...I was quite shocked) which would have the window lower and it would align with the cylinder just as it should...
So in his opinion all the imperfections should be removed, to increase flow. Obviously he is aware of things such as crankcase pressures, transfer duration, inlet duration, etc..
I asked previously about some tips from builders here, all I got is the info that I should be careful, blah blah..nothing concrete...
If this setup turns to be good I am going to post the dimensions of it so everybody can benefit from having a simple oem low cost setup.
