BruceSki
Formerly Motoman25
- Long Island
62T/61X engine
Fiberglass reeds
Minor case porting
Minor cleaning up of transfer ports on cylinders on the bottom side. Exhaust port was left alone, and transfers up in the cylinder were not touched.
.50 over pistons
New crank seals
Includes engine drive coupler, flywheel bolt, keyway, stator bolts, intake manifold with reeds and all necessary hardware.
Engine was removed from a waveblaster and cleaned/re gasketed/re assembled. This motor ran very well, only reason it was replaced is the owner went bigger. Bolt on your exhaust and electronics and go.
$500 plus shipping
Sent from my iPhone using Tapatalk Pro
Fiberglass reeds
Minor case porting
.50 over pistons
New crank seals
$500 plus shipping
