- Long Island, NY
I have a 62T im putting together and its a 62T/62T motor with Dual 44mm's that im rebuilding with new gaskets, seals, and top end. However, i want to install the stock Dual 38mm Carbs for my RN Superjet, and i noticed this motors upper case which is 62T only has one Pulse Line Fitting. Its on the front carb only and it just seems to go along to the next fuel pump in some kind of In/Out loop setup.
How hard is it to add the second Pulse Line barbed fitting and is it needed for a Superjet 700 build w/pipe for regular surf riding?
Im going to be using a 61X cylinder that i already have that are freshly bored out to a set of new set of pistons..
Thanks
Thanks
