Now I'm going crazy, I found 2 diagrams that both show it in different directions...
The grommets on the ebox are facing up in the ski, so the battery cable should come off the left, and the starter off the right of the ebox if you're looking at it from the front of the ski, right? More clearly I guess, battery side should be the grommet closest to the carbs, and starter should be coming off the side closest to the exhaust... right?
