JT_Freeride
John Tetenes @Jtetenes
- Long Island
Hey guys i have been having a problem with my ski and im just looking for some help from the jetski gods.
Its a RN 701 62T
riva red pipe
Ada head 35cc domes 185 psi both cylinders
carbs specs
2.0 n/s
135 main
75 pilot
high 1.5
low 1
Pro-K F/A
Im Gonna start from the very beginning this ski has not been running up to its full potential since i put the pipe and head on. first problem i had was my carbs they where so out of whack i used WSM stuff and i will never use them again my pop off was 22 in one and 28 in the other and im sure the jets probably weren't actually the correct size. Ryan put all new mikuni stuff in and when i put the carbs on my ski it didn't quite run right so he informed me to put 130 mains back in and i did so and it ran great but no matter where i put the high speed screws it didn't seem to make a difference (plug color was actually perfect all the time). after that i went to the surf again and it was running like crap and ryan gaped my plugs real tight (i was told this was a sign of a bad stator) and this seemed to fix it and then once again the ski ran great. now like 1 month later the ski starts acting up again it would run great in the begining of the day and about 1 hour later the ski would fall on its face and as if it ran out of fuel. turns out my return line on the slave carb was clogged which makes me believe that was the reason for the 130 jets and why the high speed screws didnt matter. so i went ahead and put a new return on the carb from a slave that we had laying around ( this returns outlet is angled on a 90 and also its a bigger fitting not sure if this matters). after that i ran the ski on the trailer and it ran away so put the 135s back in and it didnt run away. i would like to add when the ski is on the trailer is revs fine and sounds fine. now thinking all is well i throw it in the water and hope for the best but of course is runs worse and now it sounds like its on 1 cylinder but will randomly take off like a bat out of hell. at idle in the water it feels great crack the throttle and it falls on its face. Now going back to the bad stator i bought a good used stator and coil and swapped them. guess what didnt fix the problem. I tested the stater and coil using the specs from the Tech FAQ and they check out i was unable to check the pulsar coil because i have a digatil meter but when i did i get 2.4 and 4 ohms which is still withing spec. But both coils tested different resistance the old coil was 4.3k which is correct and the new coil was 19k strange. its should be within 3.5k-4.7k .
The only thing i have not changed out is my CDI but im told they either work or they dont.
Any insight is greatly appreciated Brigantine is coming up and i need this thing to work lol
Thank you, John
Its a RN 701 62T
riva red pipe
carbs specs
2.0 n/s
135 main
75 pilot
high 1.5
low 1
Pro-K F/A
Thank you, John
